Ian this wave normal?
Gaber Mohamed Boraey
Full Member level 5
Full Member level 5
Hello everyone
I have inverter with modified sine wave output and 50hz , customer complaints that it doesn’t work normal with electric fans at home, say the fan work but slow and with noise sound also he can smell burning smell after a while
I’ve checked the output wave of this inverter and it looks like this “ attached “
Ive measured the output voltage and it’s within range 220vac , the inverter work normal with other loads for example a tungestin
Lamp
Does the modified sine wave signal not suitable for electric fans?
Modified sine rarely works with inductive loads such as motors.
The 'modified' sine you show is actually more like a square wave with settling time, instead of rising and falling gradually along a sine curve, it produces full positive, zero, full negative, zero, full positive, zero repeatedly. The inductive load doesn't take kindly to the abrupt rising and falling edges. Non-inductive loads don't care what the waveform is and would even work on pure DC.
Brian.
What's wrong with the flyback voltages?
What will selecting different capacitors for speed for impedance and phase shift do with harmonics?
Why are the harmonics audible yet not the fundamental f from lower impedance harmonics and edge-noise spectrum?
The tri-level inverter almost looks tri-state but not in one direction towards 0.
What's wrong with this picture? besides not being a sinewave.
You cannot use a square wave inverter or even a Triac on AC cap-controlled-speed fans due to these harmonics not shifting the phase properly.
Unless the modified shine wave is an active short circuit in the dead time - then it is hopeless for powering things like fans.
very few modified sine inverters are built like this, usually the impedance P-N in the dead time is unknown and the energy stored in the transformer output wires flies about in an effort to reset the core flux to zero.
remember real mains has a low Z at all times, including near the zero crossings - where fan current often flows due to its inductive nature.
Look into the diode-clamped converter. It's suitable for powering inductive loads. Its waveform is bipolar AC similar to the 'modified sine' inverter. Its switching sequence keeps free-wheeling diodes connected to the load for a brief portion of each idle cycle.
LaTeX Commands Quick-Menu:
