i2c scl and sda pull up resistor value help
raman00084
Full Member level 6
what value of pullup resistor can i use in scl and sda pins my i2c clock speed is 200khz and i am connecting 3 i2c devices, my microcontroller is pic18f4520 kindly help
regards
kalyan
You must refer to the slave device datasheet.
There you can find graph relating the pull-up resistor range as a function of the access speed mode.
