I2C program file problem with 8051
anboli
Full Member level 2
i have the problem with I2C program, while interfacing with ds1307 RTC.
can anyone upload the I2C header or program for the 8051 controller?
here is my source code for I2C.
void I2CInit()
SDA = 1;
SCL = 1;
void I2CStart(){
SDA=1;
SCL=1;
_nop_(); //No operation
_nop_();
SDA=0;
SCL=0;
// SCL = 1;
// _nop_(); //No operation
// _nop_();
// SDA = 0;
// SCL = 0;
void I2CRestart(){
SCL = 0;
SDA = 1;
delay(4);
SCL = 1;
SDA = 0;
void I2CStop(){
SDA=0;
SCL=1;
_nop_();
_nop_();
SDA=1;
SCL=0;
// SCL = 0;
// SDA = 0;
// LCD_delay(4);
// SCL = 1;
// SDA = 1;
void I2CAck(){
SDA = 0;
SCL = 1;
_nop_();
_nop_();
SCL = 0;
SDA = 1;
void I2CNak(){
SDA = 1;
SCL = 1;
SCL = 0;
Message is unavailable.
Reactions: anboli
    anboli
thanks for the response sir.
sir, i had taken the code from that website.
i had worked with the program, its quite running, but what was the problem occurs in the program,
its not reading the data when we specifying particular address.
more than that its working when we just copy and paste the same program.
//Program to interface Serial EEPROM AT24C02 with 8051 microcontroller (AT89C51)
#include<reg51.h>
#include<intrins.h> //For using [_nop_()]
sbit sda=P2^0;
sbit scl=P2^1;
sbit led=P2^3;
bit ack;
sbit led1=P2^2;
sfr lcd_data_pin=0x80;//p2 port
sfr output=0xA0;//p0 port
sbit rs=P3^6;
sbit rw=P3^5;
sbit en=P3^7;
unsigned char reead,write,write2,i,j,k;
unsigned int temp;
void delay(unsigned int count)
int i,j;
for(i=0;i<count;i++)
for(j=0;j<1275;j++);
void lcd_command(unsigned char comm)
lcd_data_pin=comm;
en=1;
rs=0;
rw=0;
delay(1);
en=0;
void lcd_data(unsigned char disp)
lcd_data_pin=disp;
en=1;
rs=1;
rw=0;
delay(1);
en=0;
lcd_dataa(unsigned char *disp)
int x;
for(x=0;disp[x]!=0;x++)
lcd_data(disp[x]);
void lcd_ini()
lcd_command(0x38); // for using 8-bit 2 row LCD
delay(5);
lcd_command(0x0F); // for display on, cursor blinking
delay(5);
lcd_command(0x80);
delay(5);
void aknowledge() //acknowledge condition
scl=1;
_nop_();
_nop_();
scl=0;
void start() //start condition
sda=1;
scl=1;
_nop_();
sda=0;
scl=0;
void stop() //stop condition
sda=0;
scl=1;
_nop_();
_nop_();
sda=1;
scl=0;
void send_byte(unsigned char value) //send byte serially
unsigned int i;
unsigned char send;
send=value;
for(i=0;i<8;i++)
sda=send/128; //extracting MSB
send=send<<1; //shiftng left
scl=1;
_nop_();
_nop_();
scl=0;
ack=sda; //reading acknowledge
sda=0;
unsigned char read_byte() //reading from EEPROM serially
unsigned int i;
sda=1;
reead=0;
for(i=0;i<8;i++)
reead=reead<<1;
scl=1;
_nop_();
_nop_();
if(sda==1)
reead++;
scl=0;
sda=0;
return reead; //Returns 8 bit data here
void save() //save in EEPROM
start();
send_byte(0xA0); //device address
aknowledge();
send_byte(0x00); //word address
aknowledge();
send_byte(5); //send data
aknowledge();
send_byte(65);
aknowledge();
send_byte(75);
aknowledge();
stop();
if(ack==0)
led1=1;
delay(100);
led1=0;
lcd_command(0x86);
lcd_data('5');
lcd_command(0x87);
lcd_data('A');
delay(100);
else
{led1=1;
aknowledge();
lcd_dataa("No write");
delay(100);
// send_byte(0x01); //word address
// aknowledge();
// send_byte(6); //send data
// aknowledge();
// send_byte(66);
// aknowledge();
// //stop();
// if(ack==0)
// led1=1;
// delay(100);
// led1=0;
// delay(100);
// lcd_command(0x89);
// lcd_data('6');
// lcd_command(0x8A);
// lcd_data('A');
// else
// { led1=1;
// aknowledge();
// lcd_dataa("2");
// delay(100);
// send_byte(0x02); //word address
// aknowledge();
// send_byte(7); //send data
// aknowledge();
// send_byte(67);
// aknowledge();
// stop();
// if(ack==0)
// led1=1;
// delay(100);
// led1=0;
// delay(100);
// //lcd_command(0x01);
// lcd_command(0x8c);
// lcd_data('7');
// lcd_command(0x8d);
// lcd_data('A');
// else
// {led1=1;
// aknowledge();
// lcd_dataa("3");
// delay(100);
void Read()
start();
send_byte(0xA0);
aknowledge();
send_byte(0x00);
aknowledge();
start();
send_byte(0xA1); //device address
aknowledge();
i=read_byte();
aknowledge();
j=read_byte();
aknowledge();
k=read_byte();
aknowledge();
stop();
if(i==5)
led=0;
delay(100);
led=1;
delay(100);
write=i+48;
lcd_command(0xC6);
lcd_data(write);
delay(50);
else
led=1;
lcd_command(0x01);
lcd_dataa("No Read of i");
delay(100);
if(k==75)
lcd_command(0xC7);
lcd_data(k);
delay(50);
else
{lcd_command(0x01);
lcd_dataa("No Read of j");
delay(100);
if(j==65)
lcd_command(0xC7);
lcd_data(j);
delay(50);
else
{lcd_command(0x01);
delay(100);
//aknowledge();
i=0;
j=0;
//*****************************second read*****************
// start();
// send_byte(0xA0);
// aknowledge();
// send_byte(0x00);
// aknowledge();
// start();
// send_byte(0xA1); //device address
// aknowledge();
// i=read_byte();
// aknowledge();
// j=read_byte();
// aknowledge();
// stop();
// if(i==5)
// led=0;
// delay(100);
// led=1;
// delay(100);
// write=i+48;
// lcd_command(0xC9);
// lcd_data(write);
// delay(200);
// else
// {lcd_command(0xC9);
// lcd_dataa("1");
// delay(100);
// led=1;
// if(j==65)
// lcd_command(0xCa);
// lcd_data(j);
// delay(200);
// else
// {lcd_dataa("1");
// delay(100);
// led=1;
//// aknowledge();
void main()
lcd_ini();
lcd_dataa("Sent :");
lcd_command(0xC0);
lcd_dataa("Read :");
temp=0;
save();
while(1)
Read();
try this code
#include<intrins.h>
#include<reg51.h>
sbit rs=P0^1;
sbit rw=P0^2;
sbit en=P0^3;
sbit en1=P2^7;
sbit sda=P1^0;
sbit scl=P1^1;
void i2c_start();
void lcd_init1();
void i2c_stop();
void data_init();
void display_routine(unsigned char);
void slave_address(unsigned char);
void data_write(unsigned char);
unsigned char data_read();
void ack();
void ack1();
void m_ack();
void m_nack();
void lcd_init();
void data_mode1(unsigned char );
void data_mode(unsigned char);
void command_mode(unsigned char);
void busy();
unsigned char ch1[][5]={"sun","mon","tue","wed","thur","fri","sat"};
unsigned char ch[7],x;
int main()
unsigned char i=0,b=0,c=0,z=0;
P2=0x00;
rs=0;
rw=0;
en=0;
en1=1;
scl=0;
sda=0;
i2c_start();
slave_address(0xd0);
ack();
data_write(0x00);
ack();
data_write(0x00);
ack();
data_write(0x08);
ack();
data_write(0x07);
ack();
data_write(0x4);
ack();
data_write(0x6);
ack();
data_write(0x6);
ack();
data_write(0x12);
i2c_stop();
lcd_init();
//while(1)
command_mode(0x83);
i2c_start();
ack();
data_write(0x00);
ack();
i2c_start();
slave_address(0xd1);
ack();
for(i=0;i<7;i++)
ch[i]=data_read();
if(i==7)
m_nack();
else{
m_ack();
i2c_stop();
display_routine(ch[2]);
data_mode(':');
display_routine(ch[1]);
data_mode(':');
display_routine(ch[0]);
command_mode(0xc0);
data_mode1(ch[3]);
command_mode(0xc7);
display_routine(ch[4]);
data_mode('-');
display_routine(ch[5]);
data_mode('-');
display_routine(ch[6]);
return 0;
void data_write(unsigned char a)
unsigned char i=0,x=0;
for(i=0;i<8;i++)
if(a&0x80)
sda=1;
else
sda=0;
scl=1;
_nop_();
_nop_();
scl=0;
a=a<<1;
unsigned char a=0,b=0,c=0,i;
sda=1;
for(i=0;i<8;i++)
a<<=1;
if(sda)
a=a|0x01;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
return a;
void slave_address(unsigned char a)
data_write(a);
void ack()
sda=0;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
if(sda==0)
else
void m_ack()
sda=0;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
void m_nack()
sda=1;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
void i2c_start()
sda=1;
scl=1;
_nop_();
_nop_();
//_nop_();
sda=0;
scl=0;
void i2c_stop()
sda=0;
scl=1;
_nop_();
_nop_();
sda=1;
scl=0;
void command_mode(unsigned char a)
//delay();
busy();
P2=a;
rs=0;
rw=0;
en=1;
_nop_();
_nop_();
en=0;
void data_mode(unsigned char a)
busy();
P2=a;
data_init();
void data_mode1(unsigned char p)
unsigned char j=0;
busy();
p=p-1;
while(ch1[p][j]!='\0')
P2=ch1[p][j];
data_init();
j++;
void data_init()
rs=1;
rw=0;
en=1;
_nop_();
_nop_();
en=0;
void lcd_init()
command_mode(0x01);
command_mode(0x38);
command_mode(0x06);
command_mode(0x0c);
command_mode(0x80);
void busy()
en1=1;
rs=0;
rw=1;
while(en1)
en=0;
_nop_();
_nop_();
en=1;
void display_routine(unsigned char ch)
unsigned char b=0,c=0;
b=ch&0x0f;
b=b|0x30;
c=ch>>4;
c=c|0x30;
data_mode(c);
data_mode(b);
hope this helps
In this code I'm trying to determine what the:
sbit en1=P2^7;
is referring to. An LED state, indicator? Used in place of an int value maybe?
#include<intrins.h>
#include<reg51.h>
sbit rs=P0^1;
sbit rw=P0^2;
sbit en=P0^3;
sbit en1=P2^7;
sbit sda=P1^0;
sbit scl=P1^1;
void i2c_start();
void lcd_init1();
void i2c_stop();
void data_init();
void ack();
void ack1();
void m_ack();
void m_nack();
void lcd_init();
void busy();
int main()
P2=0x00;
rs=0;
rw=0;
en=0;
en1=1;
scl=0;
sda=0;
i2c_start();
ack();
data_write(0x00);
ack();
data_write(0x00);
ack();
data_write(0x08);
ack();
data_write(0x07);
ack();
data_write(0x4);
ack();
data_write(0x6);
ack();
data_write(0x6);
ack();
data_write(0x12);
i2c_stop();
lcd_init();
//while(1)
command_mode(0x83);
i2c_start();
ack();
data_write(0x00);
ack();
i2c_start();
ack();
for(i=0;i<7;i++)
ch[i]=data_read();
if(i==7)
m_nack();
else{
m_ack();
i2c_stop();
data_mode(':');
data_mode(':');
command_mode(0xc0);
data_mode1(ch[3]);
command_mode(0xc7);
data_mode('-');
data_mode('-');
return 0;
for(i=0;i<8;i++)
if(a&0x80)
sda=1;
else
sda=0;
scl=1;
_nop_();
_nop_();
scl=0;
a=a<<1;
sda=1;
for(i=0;i<8;i++)
a<<=1;
if(sda)
a=a|0x01;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
return a;
data_write(a);
void ack()
sda=0;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
if(sda==0)
else
void m_ack()
sda=0;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
void m_nack()
sda=1;
scl=1;
_nop_();
_nop_();
//_nop_();
scl=0;
void i2c_start()
sda=1;
scl=1;
_nop_();
_nop_();
//_nop_();
sda=0;
scl=0;
void i2c_stop()
sda=0;
scl=1;
_nop_();
_nop_();
sda=1;
scl=0;
//delay();
busy();
P2=a;
rs=0;
rw=0;
en=1;
_nop_();
_nop_();
en=0;
busy();
P2=a;
data_init();
unsigned char j=0;
busy();
p=p-1;
P2=ch1[p][j];
data_init();
j++;
void data_init()
rs=1;
rw=0;
en=1;
_nop_();
_nop_();
en=0;
void lcd_init()
command_mode(0x01);
command_mode(0x38);
command_mode(0x06);
command_mode(0x0c);
command_mode(0x80);
void busy()
en1=1;
rs=0;
rw=1;
while(en1)
en=0;
_nop_();
_nop_();
en=1;
b=ch&0x0f;
b=b|0x30;
c=ch>>4;
c=c|0x30;
data_mode(c);
data_mode(b);
Compiles perfect, but no display.
Any ideas?
In this code I'm trying to determine ...
The question sounds pretty usesless (as well as the old post preceeding it) I think.
Any usefull code would refer to a specific known hardware.
