I2C pic16f877a slave and master
bajra.pradeep
Can someone help me with PIC16f877a to PIC16f877a i2c communication using hi-tech c compiler in MPLAB? The slave seems to give ACk when i2c debugger in in connection in proteues.
here is my code and proteus simulation. please help. even my eeprom doesn't seen to work now
  • I2C#PICTOPIC.7z
Can anyone please help me with pic16f877a as slave with pic16f877a as master. Please reply, its an emergency
Find the attached file. Its a working code for the master and slave device (PIC16f877a to PIC16f877a) code. Proteus file are also there.
enjoy!
  • I2C.rar
Reactions: Doom11 and zia
    zia
    Doom11
i have master to slave transfer in but i am searching for code for slave(PIC16f877a) to master(PIC16f877a) transfer.please reply.
Read about I2C communication from https://www.i2c-bus.org/slave/. After reading you will understand how to trasfer data from a slave device to master device.
The slave cannot start a message, it can only respond to a message initiated by a master. The master requests a response from a particular slave as defined by the device address byte in the I2C protocol. The slave module answer to the master at the appropriate times as defined by the protocol.
You need to develop the code by yourself.
does anyone have hardware test videos or help for me for pic to pic connection using i2c. My code is well running in proteus but no expected response is there in real world
Have you pulled-up MCLR pins of Master and Slave? Have you pulled-up SCL and SDA lines high with 4.7K resistors? Post your latest working project files and Proteus file.
I did all that you have mentioned.ok this is my code for master to slave communication. i have simply sent a signal to slave and that signal is again tranferred back to the master. Master Pic is on the left.Please see the bug and help me set this up in real.
  • I2C#PICtoPICretry.zip
