benjamin42
Newbie level 3
On the following image, we can see an MPU-9150 from Invensense being interfaced with an Arduino.
I want to interface it with an interface board for the TinyDuino:
I do not understand why the SDA/SDL connectors are linked to A2 and A3 pins, is this mandatory and arbitrary? Can I change it to any other pin? Behind the scene I use an I2C library (Wire) to communicate with the device, so I would just need to make sure the connections are well made.
Also, is it a good idea to glue the other sensor board on the Proto board?
Thank you very much
Thank you very much
