[General] i want to vary the ultrasonic frequency with output of light sensor in pic16f887
jayaprakash jp
Newbie level 3
please help me i want a program in which i need to vary the frequency of ultrasonic sensor from the output of proximity or light sensor
is this possible
char txt[6];
#define TRIG PORTB.F6
#define ECHO PORTB.F7
// LCD module connections
sbit LCD_RS at RA1_bit;
sbit LCD_EN at RA3_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_RS_Direction at TRISA1_bit;
sbit LCD_EN_Direction at TRISA3_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
double distance;
void main() {
INTCON = 0x00; //turn off interrupts
ADRESH = 0x00;
ADRESL = 0x00;
ADCON1 = 0x06; //all inputs are digital
ADCON0 = 0x00;
ADCON0 = 0x00;
ANSEL = 0; // Configure AN pins as digital I/O
ANSELH = 0;
C1ON_bit = 0; // Disable comparators
C2ON_bit = 0;
TRISD = 0x00; //PORTD is output
PORTD = 0x00;
TRISA = 0x00;
PORTA = 0x00;
porta.f2=0;
Lcd_Init(); //Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
PORTA.F2=0;
TRISB.F6 = 0;
TRISB.F7 = 1;
OPTION_REG.T0CS = 0;
OPTION_REG.PSA = 0;
OPTION_REG.PS0 = 1;
OPTION_REG.PS1 = 1;
OPTION_REG.PS2 = 1;
while(1){
TRIG = 0;
delay_us(10);
TRIG = 1;
delay_us(10);
TRIG = 0;
while(ECHO==0);
TMR0=0;
while(ECHO==1);
distance = (double)TMR0 * 4.352;
wordtostr(distance,txt);
lcd_out(1,6,txt) ;
Delay_ms(500);
Don't see how the code is related to "output of proximity or light sensor" or "frequency of ultrasonic sensor".
What do you mean with "frequency of ultrasonic sensor". Ultrasonic carrier frequency or pulse repetition rate?
my aim to vary the frequency from 30khz to 60khz,im using here frequency generator that is crystall oscillator,,then im using colour sensor here if the colour intensity is dark my frequency hav to increse
