mabauti said:without using 555/PICs and using XTALs preferably.
any ideas?
newelltech said:Use the power line 50/60 Hz. This frequency is kept very accurate over the long term because so many clocks use it. Just use a small transformer, hard limit the AC to form a digital clock and count it up to 36000 with a single 16 bit counter IC. Just a couple of parts and some resistors, caps and a diode.
It's easier to use than, say, gravity, the boiling point of water or eeeeeeeeeeeeeeeeee 8O .
diagram ? ; I couldn't find a 32Khz Xtal (I'll keep searching) Is there any way using a 2MHz XTal?you start with a crystal oscillator such as 32 kHz. Tnen divide down by the proper amount to get a ten minute period.
Good idea, but I still can't find a 28Khz Xtal (as above : I'll keep searching for it)I would use a 28KHz crystal oscillator. That should get you pretty close to 10 min. pulse generation.
There's not that part in my city, I will take in account that anyway.You may consider to use RTC module, e.g. BQ4850 from TI.
Yep, but I want to keep my circuit with a few components.Use a watch crystal, 32.768kHz and divide that by 2^15 to get 1 second. Then divide that by 600 to get 10 minutes.
My goal is to use a battery with my circuit.Use the power line 50/60 Hz. This frequency is kept very accurate
low 1
pause 100
loop1:
high 1 ' output 1 goes high ..
for b1 = 1 to 10 ‘ 10 loops ..
pause 60000 ‘ wait 60 seconds ..
next b1
low 1 ' output 1 goes low ..
pause 100
goto loop1
Would u please advise how accurate is the method you proposed to generate a 10-min pulse? Thanks.IanP said:Much, much easier, and much much smaller, as far as number of components is concerned, will be to use small microcontroller such as for example PICAXE-18 ..
With 4MHz crystal the code required to generate 10min pulse may look like this:
Code:low 1 pause 100 loop1: high 1 ' output 1 goes high .. for b1 = 1 to 10 ‘ 10 loops .. pause 60000 ‘ wait 60 seconds .. next b1 low 1 ' output 1 goes low .. pause 100 goto loop1
http://www.rev-ed.co.uk/docs/picaxe_manual1.pdf
Any other option must include crystal, oscillator, frequency divider and some additional logic, that's why I do think the "microcontroller" option is so tempting ..
Regards,
IanP
low 1
pause 100
loop1:
pause 60000 ‘ 10 loops ..
pause 60000
pause 60000
pause 60000
pause 60000
pause 60000
pause 60000
pause 60000
pause 59999
pause 100
goto loop1
OK 555 will not be precise for 10mn timemabauti said:without using 555/PICs and using XTALs preferably.
any ideas?
To clarify, mabauti, you have placed the following restrictions on your pulse generator:mabauti said:without using 555/PICs and using XTALs preferably.
