I want a circuit that switches from ACtoDC ...
mabauti
Member level 4
Member level 4
power supply to battery powered when the ACtoDC power supply goes below 4 volts
The circuit has 5V for nominal supply, both ACtoDC supply & battery supply
any ideas?
hi
there is a pdf file attach hear will help you
I'm sorry. I'll say it in a different manner :
I want a circuit that if detects an AC failure switches to battery powered; and if the AC line is OK then return to AC powering.
A much clearer this time. The circuit is like a emergency light that when the AC power is OFF, the battery will the one to supply and vice versa. You just need a 5V supply..
Just one question is the battery rechargable?
let say that it can be either normal or rechargeable
See attached...
Hope this can solve your problem.. Its just a simple reference design..
As you can see the output is coupled to N and P Channel FET, this are just fast switching MOSFET that will switch between supplies. If theres a Power, the output voltage will came from the LM7805 which will enable the N-channel FET to produced the desire output, and when theres a no power the P-channel FET will the one to be enable to produce the desired output..
As you can see the battery charger is very simple, you can couple a battery charger circuit to enchance the charging to the battery..
Enjoy..
    mabauti
Thanks a lot Gundam001 , I'll try that =)
Its my pleasure, if there still a question just feel free to ask...
