i use pic16f676 ic and triac for fan speed controlling
jayesh9714
Newbie level 1
Newbie level 1
Hello
Friends
Please help me any one.
my hardware is complete and ok.
But my programming of program in few misteck.
I have use pic16f676 ic and bta12 triac.
All applice can be ob/off.
But
When
I connected Fan that time fan will not start.but only doing harmming of fan.
I have also apply zero cross detection In program
And i also use pwm base singal
Thus for that
when i start my device on/off bey nec remote,that fan will not start and system is hange.
Please give me solutions of programing
I also use el3021 opto copler.
Please help me
Thanks
I used a triac in my homebrew fan speed control. The fan was a 'squirrel cage' type (mounted on a wood stove). The type is important. As I understand it, most fans cannot be speed-controlled by a triac, with their rpm dependent on the frequency of the AC supply.
If you simply limit power (as with a triac), the normal fan tries to spin at full frequency. When you continue to reduce power, there comes a point where it doesn't spin at all. I guess that's when you get only the humming noise.
Ceiling fans are a different animal. You may be able to control one of those with your pic.
