I/O cell and connection zone distance
hrkhari
Full Member level 4
Full Member level 4
Hi Guys:
I can't ssem to find the requirement of the preferable distance between the I/O cell and the connection zone of a bonding pad from the Physical Design Rule documentation. As a rule of thumb what would be a preferable distance between the I/O cell and the connection zone of the bonding Pad?. Thank You
Rgds
Depends on your packaging house..
A safe rule of thumb is 1/3 bond pad opening.
ie: if pad = 90 , then space should be around 30..
20 if you want to push it.. This is a generic rule.
I've got 24 years doing layout.. this is my conclusion. ;')
