I need to solve differential Equation
penrico
Full Member level 5
Full Member level 5
Argentina
I need to solve: (All steps to do it)
A sen(wt) = C δV(t)/δt + 1/L ∫(V(t) δt) + 1/R V(t)
where w ≈ 1/(2 pi sqrt(LC))
Need to get V(t)???
It's the superegenerative initial formula, but I'm looking all the steps to get the sollution.
thanks.
Your question is unclear due to the following:
1. What is "A sen(wt)"?
2. Does 1/R V(t) mean V(t)/R or 1/(R*V(t))?
3. Since you didn't specify boundary or initial conditions, do you mean to seek for general solutions?
This is simple integro differential equation for LCR series circuit!
Apply KVL and you will get it!
Initial conditions can be assumed to be zero!
The initial conditions are not zero, the equation has an exitation that is A sin(wt). Its a sinuidal wave.
I'm looking for general sollution in equations form.
Thanks
Hi there,
This problem can be simplified as a parallel RLC circuit with a sinusoidal forcing function. To solve this problem you need to find the complete response, v(t) = vn(t) + vf(t), where vn(t) and vf(t) are natural and forced responses, respectively.
The natural response, vn(t), should be in the form of
vn(t) = D*exp(s1*t) + E*exp(s2*t) [second order circuit]
where s1 and s2 are roots of the following characteristic equation
s^2 + (1/(R*C))*s + (1/(L*C)) = 0
the unkonwns, D and E, will be determined later using initial conditions
The forced response, vf(t), should be in the form of
vf(t) = F*sin(w*t) + G*cos(w*t) [the forcing function is 'A*sin(w*t)']
the unknowns, F and G, can be determined by substituting vf(t) in the original differential equation ( this can be done because vf(t) is one of its solutions). Then, you can use the method of undetermined coefficients to find F and G.
HTH
    penrico
This is 2nd order differential equation for LCR series circuit. so use complementary function and particular integral to solve it.
Hello friends,
I maybe wrong here but I believe that the above equation is a RLC parallel circuit (not series).
KCL: I(t) = Ic(t) + Il(t) + Ir(t) where
I(t) = A*sin(w*t)
Ic(t) = C*dV(t)/dt
Il(t) = (1/L)*Integrate(V(t))dt + Il(t=0)
Ir(t) = V(t)/R
HTH
Dspnut,
The only thing that is obscure to me is the term Il(t), which is a integral. According to the original poster, Il(t) is a indefinite integral, then the problem can be transformed to a equivalent ordinary differential equation of second order and, therefore, the solution, provided by your previous post, is perfect. If, however, the integral Il(t) is a definite one, then your solution would be problematic. The reason is that, while you can specifify V(0), you are not entitled to specifiy V'(0) as you can get it directly from the equation. In this case, you won't be able to decide the constants "D" and "E" in your previous post, as you only have one condition which is about V(0).
you can use a derivation with respect of t, then you'll have a DE of second order, use the caracteristique equation: r²+r/(RC)+1/(LC)=0, when getting the solution it's the general one, so you must get a particular solution.
Hello friends,
I do agree with steve10 that we need two initial conditions (V(0) and V'(0)). My first impression from reading penrico's post is that both initial conditions are availble. Penrico should be able to clarify this. :)
Cheers
