TomKroscavage
Newbie level 1
- Joined
- Dec 24, 2009
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Ketchikan, Alaska
- Activity points
- 1,289
I have a **broken link removed** with a PM 24 VDC 1A 420 RPM 10.2:1 gear-motor. This spoolgun has a speed control built into the handle. Normally the spoolgun uses a **broken link removed** that is a simple 24vdc supply, but features a board-mounted potentiometer that can alter motor acceleration rate to optimize arc starting. the WC-24 will not work on my application. I bought this**broken link removed**. I need to slow down the wire feed until the weld area heats up
How do I add an acceleration control to this power supply?
