I need p channel mosfet 500V & 50 Amp
irfan42
pakistan
p channel mosfet
Hi
Dear fellows I need a P channel mosfet operating voltage around 500-600 and 50-60 amp
thanks.
mosfet p 2 amp. 500v
Don't think, that you'll find any. From IXYS, you get at least 600V/32A.
500v n-channel mosfet
Thanks but can you please tell me the actual product number of P channel Mosfet. because I can't find in market.
20 ampere 500v p channel mosfet
You can find ample numbers of various P and N channel mosfets at www.irf.com. Have a look which suits you the best. Good luck.
high voltage p channel mosfet
thank you, Now please tell me how can I drive a N - channel Mosfet without using a gate driver?
mos fet 600v 22amper n channel
For the said devices, check www.ixys.com. I don't think you get them in an electronics market, possibly from a qualified catalog distributor.
IRF hasn't any high voltage P-MOSFET, unfortunately.
mosfet n channel amplifier
Difficult to get P channel with that sort of specification. Source of availability will be less I think.
mosfet 10 amper n
Check the Website of IXYS. I used 11P50 of their products which is of 500V and 11A. I could not find more powerful Type. IXYS may produce now, who knows.
Re: mosfet 10 amper n
Mouser now stocks the IXYS 600V 10A P channel part, P/N IXTH10P60. In fact I just ordered 5 pieces. It is in a TO-247 package, although IXYS also makes one in a smaller package (not however stocked at this time by Mouser).
This voltage really helps me, as I was looking at an otherwise far more complicated structure for a high-voltage-compliance current source. The source has to handle a 200V rms voltage swing at the output.
