I need hex file for a simple program for AT89S8252 and AT90S2313
Jack// ani
Advanced Member level 3
I had just finished with my programming board for AT89S8252. Now I’m very eager to test it, although I have many example programs, but not having compiles to convert them into hex(i have to download it).Now it will be very nice if someone out there can give me the hex file for a simple program to blink led at any port specified by you?
Thanks
Added after 5 minutes:
Hey I forgot to mention I also need a similar hex file for AT90S2313.
Thanks again.
give out your hex file
Someone could claims that you're too lazy to search. Not mention the knowledge you gain by doing this. Hope it's not a homework.
For 8051
https://www.iguanalabs.com/1st2051.htm
This have quite nice explanation. Sometimes it's not enough only to download the hex code inside your micro. You need to understand why your micro behaves like that.
For AVR
Re: I need hex file
Oh, come on. Can't you try to compile your own example programs yourself, so you can make your HEX files for your own?
If you are using ASM, then try ASM51 (from metalink). It's good and well known.
For avr, download AVR Studio (version 3.56 is good enough).
Re: I need hex file
Can you please tell me where can I download this older version of AVR Studio 3.56. The newer version is useless for me and quite big to download.
Thanks
