nikens
Junior Member level 2
PIC power supply circuit
I am thinking to build my power supply circuit based on L78M05CV ic.
Does this ic has any protection agains harmful voltage spikes (normal thing in car electrical environment) and I just need to add 0.1uF and 0.33uF ceramic capacitors, or do I need to build more complex circuit with big electrolytic capacitor on the input side and possibly a 15V reversed biased zener? If I need to add extra capacitor and zener will the below circuit be fine?
Also what should be the value of capacitor near the MCUs vcc and gnd pins? Someone suggested me to use 100nF, but those capacitors are to big to be solder below the MCU (on the 28DIL socket).
