I need help with output buffer
mitgrace
Full Member level 6
Full Member level 6
Out Bufffer ?
Dear All :
I design a buffer circuit , It need SFDR is 65dBc , and fix out common volatge about 0.55v .It is apply in Giga-ethernet . Does anyone have any comment . Thanks
Re: Out Bufffer ?
You can refer to this paper. It explain the method to have a fix common mode voltage for a output buffer.
Title : A CMOS 10-Gb/s SONET Transceiver
IEEE Journal Of Solid State Circuits, Vol.39, No.7, July 2004
Regards,
Suria
Re: Out Bufffer ?
ok, I also want to know,if it is used in a very high speed comparator and will drive a heavy load.how to do it?
