I need Help with ATMega16..... urgent
Eng_SAME7
Junior Member level 2
Hello guys hope you are fine,
I'm working in a project using ATMega16, and I have a timer / Coin acceptor. this timer will take a number of pulses from the ATMega16.
but the thing is that the ATMega can output from 10 mA - 20 mA I think... but my concern from the timer may take more than that...
so I need a simple schematic for a protection circuit using OPTO-Isolator or transistor to protect ATMega16..
I'm not sure what the requirements are, how much current do you need?
Do you need the opto isolation or not?
A low side switch looks like
with the load in place of the relay.
Alex
The requirements are that:
- Timer "load" may take more current from the ATMEGA16, and this can damage the ATMEGA.
- Yes I need an opto-isolator for protection.... so I need the connections "schematic diagram"...
hope u can help me
