Antenna Lover
Newbie
I recently measured the S11 curves of a 2.4GHz monopole antenna in air and water. The resonant frequencies were 2402.42MHz and 2032.82MHz respectively. Theoretically, the resonant frequency in water should be the antenna operating frequency 2400MHz divided by the relative dielectric constant of water in the square root(80), which is 268MHz. Why is the experimental result so different? I have changed the container of different sizes.
