dasrupam
Newbie level 5
hello guyz,
My Advisor want me to design a MRI RF coil by using HFSS.Problem is I am very much new to the HFSS. I need to operate this coil at two different frequencies 64 Mhz(1.5T) and 300 Mhz(7T).That means 64 Mhz and 300 Mhz should also be the resonance frequencies.Feeding should be L or C and I need to match the impedance to produce resonance. My question is how can I define L or C feeding in HFSS? Does resonant frequency depend on the coil structure? How can I do LC matching to produce the resonant frequency? Please I need some suggestions..Thank You.
