Xeeshan143
Junior Member level 3
Hello friends, Please help me out regarding the problem I am facing, I would like to find the voltage and current after each wire of the coil, (here I put some segments (segments are capacitors)).
I'm not sure how to find the voltage and current (which must be reduced because of the theoretical aspect)... for example, if I give 100A and then pass 100A through each turn of the inductor, the current and voltage must be reduced.
The pictures are shown below... Your help will be greatly appreciated by the researchers. Thanks in advance. I'm waiting for the positive comments from you people.
