GeoffL
I'm a software engineer by day and I don't have any experience designing circuitry but I have a simple project which I was hoping you guys (or gals) could help me with.
I currently have a momentary switch that triggers the circuit to close and prompt the action to occur I would like to introduce another source which can close that circuit as well. The other source will trigger the action when its power is removed or added.
One caveat is that I need a counter so that if the momentary switch is pressed and then the power is removed from the other source, the action will not fire again. However, if the momentary switch is pressed an even number of times, the other source will fire the action as necessary.
I realize that I need a relay to monitor for the removal of power from the other source and a binary counter in order to keep track of how many times the momentary switch has been pressed.
This is going in a vehicle so the power requirements are low.
Any help with components and wiring that you all can provide would be much appreciated.
Thanks!
Thanks!
