I need frequencies converter circuit
moh_monem43 said:
I have 2KHz square wave signal
How can I change this frq to become 2.7 KHz?
Thanks
One complex method
Using the 2KHz square wave signal as the reference signal of PLL, you can get a 54KHz signal, and then divided this frequency by 20, you will get 2.7Khz.
By the way, what's your application?
sixth
thanks
My Application as follow:
in automobile some sensors give 2 kHz signal, this signal not sufficient to make car's computer give suitable signal to injector, so i need increase this freq.
Use a small microcontroller - 8-pin PIC, PIAXE, or similar ..
Program one pin as input to sense transitions (high-to-low and low-to-high) of the incomming 2kHz signal and program another pin - output - to send out 2.7kHz (or whatever you need) signal as soon as it senses 2kHz on the input pin ..
Regards,
IanP
