Hishamsaleh
Full Member level 1
HI,
I'm working on a posetioner device which locate beem or transmitter scource position... what I need is to build an array antenna with electronic scan structure to locate the source w/t moving the antenna or rotating it... you can see the attached pic if the idea is not clear yet.. or submet your question and I'll reply...
thanks..
Hisham
thanks..
Hisham
