i need a similar modem code plzzzz
Enzoo
Newbie level 5
Newbie level 5
tda5051 similar
hi i have TDA5051A modem but it did not work i sarch about any similar modem if u have plz send its code thx
A modem is a modem, all you need is another modem that uses the same technology that your current modem uses. For example, if your current modem uses v.90, you find another modem that supports v.90 . Other than that most modems are the same.
Hi Enzoo,
Here is the link for the DataSheet:
https://www.alldatasheet.com/datasheet-pdf/view/PHILIPS/TDA5051.html
There are no commands to use this modem. What ever data you will make using the DATA/out pin, thats what you will get on the other side in the DATA/in pin of the power line. Please re-read the data sheet.
If you have any specific question, then post them here.
Good luck.
