I need a project in Embedded Systems?
TheSniper
Member level 3
Member level 3
I need a project about using Embedded Systems in washing machines
ie : i will use a microcontroller to create the E.S
and i am open to any ideas
thanks
hi Sniper ;)
may be its best if u read some articles. like
https://www.embedded.com.or some microsoft contest projects.
the firm that i had training made power consumption at washing machines.hope this sounds good?!or should it be a new foundation?
    TheSniper
I think that a good idea will be to select ICs that use the I2C bus.
To control them you will need only 2 lines: SDA (data) and SCL (clock). Your microcontroller will become a master and all other devices (temperature sensors, ...) will becom slaves. Transmission is quite fast so you will be able to controll motor(s), pump, valves, display ..et cetera.
    TheSniper
