I met some WARNING when run icfb, ask for help!
harryzhu
Member level 3
Member level 3
I installed IC5 on redhat 8 and when I run icfb, I met some WARNING in CIW window. It's the info in below:
\o 8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
\w *WARNING* envSetVal: Can't set the value of variable 'remasterInstSearchViewText',
\w in tool[.partition] 'layout' - it has not been registered.
\w *WARNING* envSetVal: Can't set the value of variable 'remasterInstSearchLibText',
\w *WARNING* envCyclicStringToIndex: could not find variable 'anchor'
\w *WARNING* envSetVal: Can't set the value of variable 'anchor',
\w *WARNING* envSetVal: Can't set the value of variable 'pinLargerMaxProcessWidth',
\w *WARNING* envSetVal: Can't set the value of variable 'remasterInstCheckTerms',
\w *WARNING* envSetVal: Can't set the value of variable 'remasterInstUpdateCellText',
\w *WARNING* envSetVal: Can't set the value of variable 'measurementTextHeight',
\w *WARNING* envSetVal: Can't set the value of variable 'drdEditDisplayMarkers',
\w *WARNING* envSetVal: Can't set the value of variable 'checkMaxProcessWireWidth',
\w *WARNING* envSetVal: Can't set the value of variable 'openToStopLevel',
\w *WARNING* envSetVal: Can't set the value of variable 'measurementDisplayOn',
\w *WARNING* envCyclicStringToIndex: could not find variable 'drdEditMode'
\w *WARNING* envSetVal: Can't set the value of variable 'drdEditMode',
\w *WARNING* envSetVal: Can't set the value of variable 'allowViaOnCurrentLayer',
\w *WARNING* envSetVal: Can't set the value of variable 'tapType',
\w *WARNING* envCyclicStringToIndex: could not find variable 'chainMode'
\w *WARNING* envSetVal: Can't set the value of variable 'chainMode',
\w *WARNING* envSetVal: Can't set the value of variable 'alignDirection',
\w *WARNING* envSetVal: Can't set the value of variable 'alignApplySpacings',
\w *WARNING* envSetVal: Can't set the value of variable 'remasterInstSearchCellText',
\w *WARNING* envSetVal: Can't set the value of variable 'alignSeparation',
\w *WARNING* envSetVal: Can't set the value of variable 'checkMaxStackViaDepth',
\w *WARNING* envSetVal: Can't set the value of variable 'alignMethod',
\w *WARNING* envSetVal: Can't set the value of variable 'measurementDisplayTypes',
\w *WARNING* envSetVal: Can't set the value of variable 'remasterInstUpdateViewText',
\w *WARNING* envSetVal: Can't set the value of variable 'alignApplySeparation',
\w *WARNING* envSetVal: Can't set the value of variable 'alignSelectionMode',
\w *WARNING* envSetVal: Can't set the value of variable 'remasterInstUpdateLibText',
\w *WARNING* envSetVal: Can't set the value of variable 'alignLayer',
\o Loading PRshare.cxt
\o Loading LVS.cxt
\o Loading auCore.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading seismic.cxt
\o END OF USER CUSTOMIZATION
I check my .cdsinit and .cdsenv file and don't find any description of variable setting, so I'm wondering how it say 'set the value of variable ...'. Would you please help me? Thanks for your help!
Best Regards,
Harryzhu
I met these warnnings,too.The variables is setted for other version in your old .cdsenv,pls check your .cdsenv file carefully then remove them or delete your old .cdsenv file.
Good luck!
But I cannot find any variable setting in my .cdsenv file.
maybe the setup of your liense file is not correct
I can work well with it but it's disgusting to see them. so I try to resolve it.
Check you locale setting.
All most Eda tools should set locale to en_US or C.
