I met out of memory(FM-126) error when run formality in linu
harryzhu
Member level 3
Member level 3
formality run out of memory
I use redhat AS3 on one Dell PE2850 which have 4G memory and 8G swap space, when I run formality, I met such error:
Fatal: Out of memory (FM-126) Maximum memory usage for this session: 3.14456e+06 KBCPU usage for this session: 296.5 seconds
How should I resolve it? I get no more info when searching with google
You can search FM-126 in solvnet. AS3 support 3.84G memory in 32-bit LINUX. And what is your design loaded into formality. Dell server always have some problem in running EDA software. I have encountered cdsdoc FAULT problem. But no error in normal pc(same soft, same OS). You can install same OS and same soft in normal PC to see whether it is software problem or server. Good luck
