i have to calcuate the BER
abdullah gill
Member level 1
Member level 1
pakistan
i got the code from matlab for ofdm, i have added noise to it but unable to get the BER..... can someone help me out
% A: Transmitter End
% 1. Generate random serial data with M symbols (RANDSRC will do this)
% 2. Perform modulation (4-PSK = QPSK for now)
% 3. Serial to parallel
% 4. IFFT
% 5. Parallel to serial
% 1. Generate data
M = 4;
no_of_data_points = 64;
input = randsrc(1,no_of_data_points, 0:M-1);
figure(1)
stem(input); grid on; xlabel('Data'); ylabel('Amplitude');title('Input')
% 2. Modulation
msg_tx = pskmod(input, M);
scatterplot(msg_tx);
% 3. Serial to Parallel
parallel_mod_data = reshape(msg_tx,8,8);
% 4. 64-point IFFT
ofdm_msg = ifft(parallel_mod_data);
ofdm_msg_tx = reshape(ofdm_msg, 1,64);
figure(3)
plot(real(ofdm_msg_tx)); grid on;title('Real part of OFDM signal')
figure(4)
plot(imag(ofdm_msg_tx)); grid on;title('Imaginary part of OFDM signal')
noise_add=awgn(ofdm_msg_tx,20);
figure(6)
plot(noise_add);title('noise added in the signal')
% B: Receiver End
% 1. Serial to Parallel
ofdm_msg_rx = reshape(noise_add, 8,8);
% 2. 64-point FFT
msg_rx = fft(ofdm_msg_rx);
% 3. Parallel to serial
msg_rx_ser = reshape(msg_rx, 1, 64);
% 4. Demodulation
msg_demod = pskdemod(msg_rx_ser, M);
figure(5)
stem(msg_demod); grid on;title('Output')
hi, step three (3) at the transmitter and the receiver are not correct, because the output data from the modulator are already in parallel :) and the output data from the fft block also are in parallel shape.
you have to remove this step at the transmitter and the receiver.
regards
    V
but the step three at receiver end is converting the data from parallel to serial why should i omit that part .and what should i do to calculate BER?
mr abuddallah
you missing alot of concepts of doing the OFDM modualtion fft alone wont get you ofdm modualtion,
first you have to convert the data from D/A after ifft then up-convert it and transfer it to passband it(if necessary)
and to plot the BER u need to define AWGN for multipoints not only 1 point like u doing
hope this will help you
regards
Reactions: sayfee
    sayfee
@moneer thnks for guiding to the right path but i have also defined the awgn for all paths but still the graph is not upto the expectations here is the modified code
% 1. Generate data
M = 4;
eb_n0=-3:10;
% 2. Modulation
% 4. 64-point IFFT
ofdm_msg = ifft(msg_tx);
for i=1:length(eb_n0)
noise_add=awgn(ofdm_msg_tx,eb_n0(i));
% B: Receiver End
% 2. 64-point FFT
% 4. Demodulation
z(i)=sum(input-msg_demod)/64;
end
plot(z)
