I have this Dual voltage-controlled oscillator SN74S124N - make it send 45Mhz
Oliver Sunde
Newbie level 1
Newbie level 1
Hey folks
http://www1.elfa.se/data1/wwwroot/assets/datasheets/sn74s124_eng_tds.pdf
I want to make it send a 45Mhz signal out.
I have understood that it requires about 5V on the VCC pin to work. But I have not understood how I have to connect the circuit so it sends 45Mhz on a outpin. Anyone have any experience with datasheets, and or this type of circuits?
I need to know what pins should be connected to what to make one of the pins send out 45Mhz
Help would be much appriciated!
Best Regards!
Oliver :)
I think all you have to do is connect a capacitor between CX1 and CX2, pull then EN* pin low ,and apply your control voltage to RNG.
Only 45MHz ? Is that nominal , min or max?
Being a linear VCO with wide variations of stray and PN junction capacitance , nominal f is not precise. But figure 2 shows Cx=10 pF (1e-11) for Vf=Vrng=2V
Both voltages can span from 1-5V but are more linear from 1.5 to 4.5V.
Vrng is lowest range at 1V I.e. 10%, while f increase with Vf. Both voltages increase the operating frequency, while the graph in figure 2 shows @2V for both, f*C product is almost =1nF*MHz
so chose sensitive or range voltage Vrng and control voltage Vf wisely and then Cx will be around 2 to 20pF for 50MHz
