I have problem with my proteus 8.4 simulation
vratk0529
Newbie
Newbie level 1
Here are my simulation errors+messages:
ISIS Release 8.04.00 (Build 21079) (C) Labcenter Electronics 1990- 2015.
Compiling design 'C:\Users\admin\Documents\PROTEUS\display.pdsprj'.
Netlist compilation completed OK.
Netlist linking completed OK.
Partition analysis completed OK.
Simulating partition [52DCF79E]
PROSPICE 8.04.00 (Build 21003) (C) Labcenter Electronics 1993-2015.
Loaded netlist 'C:\Users\admin\AppData\Local\Temp\LISA7175.SDF' for design 'display.pdsprj'
Loaded MODDATA (8192 bytes). [U1_U1]
Loading binary file 'display.bin'. [U1_U1]
Logic race condition detected during operating point analysis.
[SPICE] Gmin step [0 of 120] failed: GMIN=0.001
[SPICE] Gmin stepping failed
[SPICE] Source step [0 of 120] failed: source factor = 0.0000
[SPICE] Too many iterations without convergence.
Real Time Simulation failed to start.
The value of resistor R3 is too high.
Seriously speaking, did you really expect a useful answer just by providing the above information without giving any clue of the schematics?
Often this type of error is caused by missing grounds, post your Proteus circuit if you want further help.
...which is a specific case of floating nodes.
As said to OP with other words, the compiler's log by itself is not sufficiently informative.
