I have problem with acrobat 5
sortlaih
Member level 3
Member level 3
I have Acrobat writer ver 5 ...
I can select any text in any file but I can't do that with any images in same files I don't why.....?
Under Windows OK? An you mean Adobe Acrobat 5.0 OK?
Then the button next to text select enables image selection of any part of the document. Do you see this button? What is your problem in using it? What is it bad behavior?
Could you show me where can I find this button....??
Hello sortlaih,
you schould look for the pressed button in the jpg.
by,
cube007
tool bars
The bottom tool bar 4th from the left. Whey you put the mouse pointer over it "graphic select tool" will show in the tool tip.
It's clear now .....
still one more Q. please............
I have 96 pages found in 26 PDF files.
I want to make that in one PDF file?
also hwo to open new PDF file .....?
Combining PDF-files into one
Use
Document | Insert Pages
command. See Help File page 111.
just select the text only
