i have Problem on Orcad. need help~~~~
wontall
Newbie level 6
Newbie level 6
no pspicetemplate for u1, ignoring
If i place IC parts from library , when simulate , Orcad always tell me
that " Less than 2 connections at node N03183"(N03183 is the IC).
but actullay i have connected IC already.~~~~~
thanks~~
no pspicetemplate for u1 ignoring
Delete that connection first the problem might be because of the overlapping of nodes. Use the wire tool then start from the point where you connect and then move the mouse till the node or pin of the chip than you will see n indicator at the end at thjat point connect it .if the problem still persist cut the part and check the wiring to that pin if some problem there rectify it and thaen paste the ic again and it will work
check ur power supply definition
binu g
no pspice template for * ignoring
the problem can not be solved. ~~
addition, a DRC warning :"WARNING: [NET0093]
No PSpiceTemplate for U1, ignoring". how i can solve it?
thanks, wait for ur reply.
no pspice template for u1
wontall
keep in mind that use pspice library for placing the components. and use the proper ground not the GND there is a Ground with 0. use that for the ground. and care the power supply used. asign in proper spice format .
check the examples provided with the tool this will guide u.
binu g
no psspice template for u1
It's clear that you don't define GND properly. Yes, learn the toturial first
orcad cannot connect wires
Hey I guess your problems is that the IC you're using isn't properly defined in the Pspice library, try on using only pspice libraries on your simulation profile, so you can avoid this kind of problems.
