matrixofdynamism
Advanced Member level 2
I have an IBIS model of a clock oscillator. I want to find out if there will be high speed effects on the clock signal. I have converted it into a PSpice model for use in Cadence design suite simulation tools. This resulting PSice model has 3 terminals which are input, output and enable. It is derived from IBIS model of a 50MHz oscillator.
An oscillator sources a clock signal. How do I get that effect on this IBIS model in simulation as it does not generate a clock automatically? Do I merely connect an ideal pulse source to the input, tie the enable high permanently and the signal at the output terminal shall be the clock wave as found in the physical device?
