mamech
Full Member level 3
question on effect of inverter technology on relay life time
hello
I knew that the life of the relay becomes less when there are sparks. so my question is: if I eliminate the source of these sparks, I could get much longer life of the relay , that exceed the described values in datasheet?
I ask about this because we are designing a board that may be able to control Air conditioning units, so I knew that most of air conditioners implements inverter technology , so this means that the load will be controlled using the soft starters (if I understand correctly) , which will not cause the sudden high current in the beginning.
moreover , we are intending to make on and off of the relay during zero crossing.
I conclude that the nature of controlling the load (using inverter), and the time of switching (during zero crossing) will enhance the life time much??
thanks
hello
thanks
