I have a question of LDV 5.1 for linux.
swgchlry
Member level 4
Member level 4
linux ldv
I have installed the LDV and set up the env varible but when i type 'nclaunch' from the console, it display a err msg:"Application initialized failed. No display name and no $DISPLAY environment variable "
Who can tell me how to deal with this?
Further more, in XWindow, nclaunch can be opened,but when i compiled the verilog file and call simtool, it tell me that can't load libudm.so, the file or dir is invalid. but i have set the lib path.help me!
setenv display 0:0 linux
hi you can try
setting your sisplay from
etc/X11
fodr with color depth of 24bit /8 bit virtual
It not because the display can't work correctly.I can start LDV in XWindow and the depth has been 24bit.
1. check $DISPLAY environment variable setting
2. find the direction where libudm.so locates and add in $LD_LIBRARY_PATH
Give attention to the color number. Try 16, 32 and 256 colors.
Just search "LDV" in the eboard, you will get the answer. the key is your LD_LIBRARY_PATH setting.
LDV work for what?
Hi
You just need to set DISPLAY variable
for csh -> setenv DISPLAY your_hostname:0.0
for bash -> export DISPLAY=your_hostname:0.0
your_hostname => ur host name / IP
eg. say my hostname is jamesbond and IP is 123.123.123.007
then for c -shell I must execute following command
setenv DISPLAY jamesbond:0
or
setenv DISPLAY 123.123.123.007:0
Hope this helps!
you need to set the environment variable in bashrc :
ld_assume_kernel=2.4.1
server: set DISPLAY=IP:0:0, export DISPLAY
client:
1. xhost+ host_ip
2. run
for X-Client by typing:
prompt$> export DISPLAY=X-Server_HostName:0 <cr>
for X-Server by typing:
prompt$> xhost+ X-Client_HostName <cr>
