Shyam Joe
Junior Member level 3
- Joined
- Aug 21, 2013
- Messages
- 28
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 322
Hi friends i changed the code lyk dis
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 module mulsubadd(clk,a0,a1,a2,b0,b1,b2,t1,t2,t3,p,c1,c2,c3,c4,c5,c6,c7,c8,c9,c10,c11); input [255:0] p; input clk; input c1,c5,c6,c7,c8,c9,c10,c11; input [1:0] c2,c3,c4; input [255:0] a0,a1,a2,b0,b1,b2; output [255:0] t1,t2,t3; wire [255:0] w1,w2,w3,w4,w5,w6,w7,w8,w9,w10,w11,w12,w13,w14; parallelreg reg_1( .din (256'b0), .clk (clk), .rst (c7), .dout (w1) ); parallelreg reg_2( .din (256'b0), .clk (clk), .rst (c8), .dout (w2) ); parallelreg a3( .din (256'b0), .clk (clk), .rst (c10), .dout (w3) ); parallelreg a4( .din (256'b0), .clk (clk), .rst (c11), .dout (w4) ); muxb a5( .a (a0), .b (w1), .s (c1), .y (w5) ); muxc a6( .a (a1), .b (b0), .c (w2), .d (256'b0), .s (c2), .y (w6) ); fpadd a7( .p (p), .a (w5), .b (w6), .t (w11) ); muxc a8( .a (b0), .b (a1), .c (w1), .d (w3), .s (c3), .y (w7) ); muxc a9( .a (b1), .b (w2), .c (w4), .d (256'b0), .s (c4), .y (w8) ); fpadd a10( .p (p), .a (w7), .b (w8), .t (w12) ); muxb a11( .a (w3), .b (a2), .s (c5), .y (w9) ); muxb a12( .a (w4), .b (b2), .s (c6), .y (w10) ); fpadd a13( .p (p), .a (w9), .b (w10), .t (w13) ); muxb a14( .a (w11), .b (w13), .s (c9), .y (w14) ); parallelreg a15( .din (w11), .clk (clk), .rst (c7), .dout (w1) ); parallelreg a16( .din (w12), .clk (clk), .rst (c8), .dout (w2) ); parallelreg a17( .din (w14), .clk (clk), .rst (c10), .dout (w3) ); parallelreg a18( .din (w12), .clk (clk), .rst (c11), .dout (w4) ); assign t1=w11; assign t2=w12; assign t3=w13; endmodule [/syntax=verilog] the sub module fpadd is [syntax=verilog] module fpadd(p,a,b,t); input [255:0] p,a,b; output [255:0] t; reg [255:0] su1,su2; reg c1,c2; reg [255:0] v1,t1,t2,u; reg [255:0] v2,w1,w2; integer i; parameter s=1; initial begin for(i=0;i<256;i=i+1) begin if(b[i]) u=a; else u=256'b0; v1=u<<s; v2=a+b; w1=v1+(~p)+1; w2=v2+(~p)+1; c1=w1[3] | v1[3]; c2=w2[3] | v2[3]; if(c1) t1=w1; else t1=v1; if(c2) t2=w2; else t2=v2; if(b[i]) begin su1=t1; su2=t2; end else begin su1=t2; su2=t1; end end end assign t=su1-su2; endmodule [/syntax=verilog] when i simulate the code i'm not getting o/p for the signals w1,w2,w11,w12,w13,w14. I think the problem is with fpadd subunit only. Also when i synthesize i get the following warnings. help me to solve. Analyzing module <fpadd>. s = 32'sb00000000000000000000000000000001 WARNING:Xst:2320 - "fpadd.v" line 15: Value for signal u in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 18: Value for signal v1 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 19: Value for signal v2 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 20: Value for signal w1 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 21: Value for signal w2 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 22: Value for signal c1 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 23: Value for signal c2 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 25: Value for signal t1 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 29: Value for signal t2 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 34: Value for signal su1 in initial block is not constant. The initialization will be ignored. WARNING:Xst:2320 - "fpadd.v" line 35: Value for signal su2 in initial block is not constant. The initialization will be ignored. Module <fpadd> is correct for synthesis. Synthesizing Unit <fpadd>. Related source file is "fpadd.v". WARNING:Xst:1872 - Variable <i> is used but never assigned. WARNING:Xst:1780 - Signal <u> is never used or assigned. WARNING:Xst:1780 - Signal <c1> is never used or assigned. WARNING:Xst:1780 - Signal <c2> is never used or assigned. WARNING:Xst:1780 - Signal <t1> is never used or assigned. WARNING:Xst:1780 - Signal <t2> is never used or assigned. WARNING:Xst:1780 - Signal <v1> is never used or assigned. WARNING:Xst:1780 - Signal <v2> is never used or assigned. WARNING:Xst:1780 - Signal <w1> is never used or assigned. WARNING:Xst:1780 - Signal <w2> is never used or assigned. WARNING:Xst:653 - Signal <su1> is used but never assigned. Tied to value 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000. WARNING:Xst:653 - Signal <su2> is used but never assigned. Tied to value 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.
