I desperately need to replace a capacitor.
Rodymens
Newbie
Newbie level 1
Hi there, I desperately need to know the component and the value of the following unit so I can replace it in a OnePlus 7 Pro mainboard.​
1) Any idea?​
I suspect that it might very well be either a 2.2 uF capacitor, or a 1 uF. It is connected to the VDD N-FET pin of a Samsung UFS.​
So I think that it is a Samsung UFS V_DD N-FET pin 0201-sized grounding ‘MultiLayer Ceramic Capacitor’ (MLCC).
2) What would happen if I installed the 1 uF while a 2.2 uF capacitor was required or vice versa?
Thank you so much in advance!​
Unless someone has the same unit or you can supply a schematic we can't tell. In all probability it will work fine but we don't know what the capacitor actually does in the circuit to be sure. You might be able to stack two 1uF capacitors one on top of the other or mount them on their sides to make 2uF total.
Brian.
LaTeX Commands Quick-Menu:
