I can't to install IC50 in RedHat7.3!Help me!
swgchlry
Member level 4
Member level 4
I'm a new user of linux and cadence. I download a copy of cds IC50 from a site and i have install it on my computer with the default option, but i can't set up the IC50.I have a license(download from that site), how to config it? Would you write the solution in detail?thanks! By the way, I use bash shell.
what site? you can email them and sak.
You can refer to this post for details:
hxxp://
x -> t
Also, use the search function and you can see a few topics related to your questions as well.
after the installition, i run icfb in the console, it tell me that xwindow display initialization failed, then i run it from the gnome,but it doesn't run and tell me nothing. I run RH73 in vmware, is the wrong message has relationship with this?But other software can run correctly.
i see, it's my visual card's fault
I think it's your display sets.you can find the way in the old subjects of this forum
u must set ur video as a true color and it need 64 mb video card memory for good performance
lot post here for installing ic 5
see that
