michaelmoore44
Newbie level 5
pnp press and peel removing blue
I have read several topics and I even have a book that discusses the toner transfer method. I am able to print off a really nice looking circuit on to the press and peel blue paper. But when i try to iron on the toner it does not stick to the copper. Does anyone have any ideas?
I am using a Brother HL 2040 laser printer. Is anyone else using the same brand or model.
I am using the Press and Peel Blue paper.
I have set the iron to the hottest it will go and also I have tried to set the Iron to the wool setting which is at the lower end of the steam setting.
I dumped all of the water out and tried to test the iron to make sure that the iron didn't have any steam in the iron.
I tried to clean the copper before I made the transfer.
I used a pice of steel wool and dish soap to clean the surface of the copper.
Then i used a sponge with the rough surface to clean it again.
Thank you for your help.
