I can't arrange the components in a PCB !!
Hunter666_444
I am building a 4 digit voltmeter PCB 10 cm by 15 cm and I tried all the alignments possible but still no way,I also tried to copy the schematic and tried auto placer tool (PROTEUS 8.6) . Any ideas ??
Thanks in advance...
First
* draw the complete schematic
* then use two layer PCB
* then do the placement according the schematic (display controller, power supply capacitors, most important signals, least important signals)
(I´d try to rotate the controller 90° clock wise and place it below the displays)
Klaus
its a uni project and I all wires to be bottom copper
here is my schematic
[found at: imgur. com /ktErFRa]
is there a solution ?
The schematic is a mess.
Clean it up. Use GND symbols. They don't cost a thing.
Avoid unnecessary crossings, avoid unnecessary junction dots, place junction dots where they belong to.
Klaus
DP current limiting resistor missing.
Single layer PCB is feasible for a simple circuit like this, but you need jumper wires.
