I can read from serial port in XP with a code for Win98!
Munib
Full Member level 1
serial port in xp
why i cant read from serial port whem i m using windows XP the same code works well in windows 98
i m using C++
Re: serial port in xp
Windows XP, and in general NT, have mechanisms in place which prevent you from accessing the serial port directly like you used did in Win95/98/Me.
In order to allow legacy code to work have a look at: **broken link removed** essentially it includes a driver which will allow older code to work.
You can access the serial port (and any other device) using the Windows API CreateFile() function and set the DCB structure. Have a look at:
- Jayson
