ahmad2005
Member level 1
- Joined
- Mar 30, 2011
- Messages
- 40
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Location
- Mirpur,Dhaka,Bangladesh
- Activity points
- 1,618
This is found in hyper terminal
here why NO CARRIER occurs?
and this is found By serial port monitor during EDGE connection process while using modem plugin play soft ware to active the internet connection in PC.
Here "Port opened by process "svchost.exe" (PID: 1300)" what does that means? what is the working principle of "svchost.exe" ? if want to connect my modem microcontroller that time i do not get "svchost,exe" in microcontroller what should i do that time ?
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 AT OK AT+CGDCONT=1,"IP","gprsunl" OK ATD*99***1# CONNECT CONNECT CONNECT CONNECT CONNECT CONNECT CONNECT NO CARRIER
Code ActionScript - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 41 54 2B 43 47 44 43 4F 4E 54 3D 31 2C 22 49 50 AT+CGDCONT=1,"IP 22 2C 22 67 70 72 73 75 6E 6C 22 0D ","gprsunl". Answer: 4/28/2011 9:21:37 PM.54264 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Port closed Port opened by process "svchost.exe" (PID: 1300) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.66764 (+0.0469 seconds) 41 54 0D AT. Answer: 4/28/2011 9:21:38 PM.66764 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.66764 (+0.0000 seconds) 41 54 20 56 31 45 30 53 30 3D 30 0D AT V1E0S0=0. Answer: 4/28/2011 9:21:38 PM.66764 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.68364 (+0.0156 seconds) 41 54 53 37 3D 36 30 26 4B 33 0D ATS7=60&K3. Answer: 4/28/2011 9:21:38 PM.68364 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.69864 (+0.0156 seconds) 41 54 53 30 3D 30 0D ATS0=0. Answer: 4/28/2011 9:21:38 PM.69864 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.74564 (+0.0469 seconds) 41 54 0D AT. Answer: 4/28/2011 9:21:38 PM.74564 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.76164 (+0.0156 seconds) 41 54 20 56 31 45 30 53 30 3D 30 0D AT V1E0S0=0. Answer: 4/28/2011 9:21:38 PM.76164 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.77664 (+0.0156 seconds) 41 54 53 37 3D 36 30 26 4B 33 0D ATS7=60&K3. Answer: 4/28/2011 9:21:38 PM.77664 (+0.0000 seconds) 0D 0A 4F 4B 0D 0A ..OK.. Request: 4/28/2011 9:21:38 PM.77664 (+0.0000 seconds) 41 54 44 2A 39 39 2A 2A 2A 31 23 0D ATD*99***1#. Answer: 4/28/2011 9:21:38 PM.79264 (+0.0156 seconds) 0D 0A 43 4F 4E 4E 45 43 54 0D 0A ..CONNECT.. [B]Port opened by process "svchost.exe" (PID: 1300)[/B] Request: 4/28/2011 9:21:38 PM.93364 (+0.1406 seconds) 7E FF 7D 23 C0 21 7D 21 7D 20 7D 20 32 7D 22 7D ~ÿ}#À!}!} } 2}"} 26 7D 20 7D 20 7D 20 7D 20 7D 25 7D 26 23 A9 5A &} } } } }%}&#©Z 7D 27 7D 27 7D 22 7D 28 7D 22 7D 2D 7D 23 7D 26 }'}'}"}(}"}-}#}& 7D 31 7D 24 7D 26 4E 7D 33 7D 37 7D 21 D8 26 97 }1}$}&N}3}7}!Ø&? A7 8D BC 4E B2 BF DB A1 7D 2B BB 6C 97 FE 7D 20 §¼N²¿Û¡}+»l?þ} 7D 20 7D 20 7D 20 8B 7D 3D 7E } } } ?}=~
