I can´t install freeware version of Eagle
etolocka
install eagle freeware
Hi!
I have downloaded the last freeware version of Eagle and I can´t install it in my W2000 machine.
When I run the installer, near the end of the unpacking operation, I got the error:
(translated from the Spanish)
"Windows 16 bits subsystem: C:\WINNT\SYSTEM32\AUTOEXEC.NT. The file can´t run MS-DOS and windows applications"
I understand that Eagle works fine with Windows 2000, so I don´t what is wrong.
Somebody can ehlp me?
Regards,
Ernesto.
install eagle english version
etolocka said:
Hi!
Regards,
Ernesto.
Hi, I also faced this problem for several times (i hope you have same problems, my autoexec.nt was missing).
The solution was in my case:
To search the disc C: for autoexec.nt and then copy it to C:\WINNT\SYSTEM32\
I think that even content of this file is not important, in my case there are many REM lines (thus with no funcionality), I only see this valid content:
@echo off
lh %SystemRoot%\system32\mscdexnt.exe
lh %SystemRoot%\system32\redir
lh %SystemRoot%\system32\dosx
(I'm running WXP SP2 but that's not valuable difference)
Cheers,
e.
