robismyname
Full Member level 6
- Joined
- Jan 17, 2008
- Messages
- 390
- Helped
- 11
- Reputation
- 22
- Reaction score
- 9
- Trophy points
- 1,298
- Location
- Central Florida
- Activity points
- 4,603
I attached a image related to my question. The image is a block diagram of a "generic" dual conversion radio I presume. What draws my attention is the baseband section that has the I branch and Q branch and to the right of this there is text that says A-to- converter.
My question are:
1) Is this particular block diagram implying I/Q modulation/demodulation?
2) Whenever I see I branch, Q branch should I always presume that this means the radio is using I/Q modulation/demodulation?
3) In reference to the TX, the A-to-D converter's input is from the FPGA,Processor,etc but how does it know that its output will be Inphase or its output will be Quadrature? Arent both A-to-D converters the same in the TX chain?
4) Is the mixer between the baseband and IF section double balanced?
5) In referecne to the TX chain, what is coming out of the I and Q branch, sine waves 90 degrees out of phase form each other?
My question are:
