I am trying to recieve voltage from MAX11040K
pnielsen
Member level 2
Member level 2
I was able to get the following code to zero all channels. But trying to read real voltages on all 4 channels?
Code is written for Cypress:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
#include <device.h>
uint32 Readvalue[4];
uint8 dummyvar;
uint8 i;
void main()
    /* Place your initialization/startup code here (e.g. MyInst_Start()) */
    CyGlobalIntEnable; /* Uncomment this line to enable global interrupts. */
    SPIM_Start();
    SPIM_ClearTxBuffer();
    SPIM_ClearRxBuffer();
//  LCD_Char_1_Start();
    SS_Write(0);                //digitalWrite(ADCCS, LOW);
    SPIM_WriteTxData(0x60);     //SPI.transfer(B01100000);     //address
    SPIM_WriteTxData(0x34);     //SPI.transfer(command1); command1 = B00110100
    while(!(SPIM_ReadTxStatus() & SPIM_STS_SPI_DONE));
    SS_Write(1);                //digitalWrite(ADCCS, HIGH);
    // For reading 3 bytes of data and sending a command byte.
    CyDelayUs(1);               //Maximum time needed for the Output pin to get enabled is 20nsec, giving a delay of 1usec.
                                //if (digitalRead(MISO) == LOW) {   // ADC Converter ready ?
    SPIM_WriteTxData(0xF0);     //SPI.transfer(B11110000);
    SPIM_ClearRxBuffer();       //Read buffer will have two + one bytes of data, so clear the RX FIFO before reading 24 bits of data as you need.
    for(i=0;i<4;i++)            // Three 8 bit Write/Reads clears memory registers
        SPIM_WriteTxData(0x00);     //b0=SPI.transfer(0);
        SPIM_WriteTxData(0x00);     //b0=SPI.transfer(0); (24 dummy/ zero bits to be sent)
        while(!(SPIM_ReadTxStatus() & SPIM_STS_SPI_DONE)); // Wait till the three bytes are sent. Or check the RXStatus if some data has been received, but that doesn't tell if all 3 bytes have been received. Thus check when the Tx FIFO is sent completly.
        dummyvar = SPIM_ReadRxData();
        Readvalue[i]|=dummyvar;
        Readvalue[i]<<=8;
        Readvalue[i]<<=8;
    //    LCD_Char_1_Position(0,0) ;
    //    LCD_Char_1_PrintString(i); ?
    //   if i = 0
    //          LCD_Char
    // May need UNION statement?
    CyDelayUs(10000);
    SS_Write(1);
    CyDelayUs(1);
   for(;;)
/* [] END OF FILE */
// Will use RS232 for com. Then RS232 to USB converter? Check Labview
