yash_01
Newbie level 5
- Joined
- Dec 26, 2024
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 76
Missing CODE or SYNTAX tags [ Added by moderator ]
i am trying to do a code using a temperature and humidity sensor (DHT11), and i am getting checksum error as my output in LCD. i am using keil uv5 and proteus simulator
what is the error in this code??
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 #include <stdio.h> #include <reg52.h> #include <intrins.h> #define lcd_data P2 int i; int temp=0; unsigned char humidity=0; unsigned char humidity_point=0; unsigned char temperature=0; unsigned char temp_point=0; unsigned char check=0; unsigned char h[]="00.0"; char a,b; sbit DTH=P3^0; sbit rs=P1^0; //reg select sbit rw=P1^1; //rewrite sbit en=P1^2; //enable void lcd_init(); void cmd(unsigned char a); void dat(unsigned char b); void show(unsigned char *s); void lcd_delay(); void lcd_init() { cmd(0x38); //defining is first, the peripherals and the line cmd(0x0e); cmd(0x01); cmd(0x06); //entry mode - after refreshing we're ready to use it cmd(0x0c); //defining cursor cmd(0x80); // start from the first row first column } void cmd(unsigned char a) { lcd_data=a; rs=0; //registers select rw=0; // write mode en=1; //enabling writing to the registers, power should be on when in use lcd_delay(); en=0; } void dat(unsigned char b) { lcd_data=b; rs=1; rw=0; en=1; lcd_delay(); en=0; } void show(unsigned char *s) { while(*s) { dat(*s++); } } void lcd_delay(){ int i; for (i=0;i<10000;i++){ } } delay_ms(unsigned char val){ if (val == 18){ TMOD=0x01; TH0=0xB9; TL0=0xB0; TR0=1; while (TF0 == 0); TR0=0; } else if (val == 25){ TMOD=0x01; TH0=0x9E; TL0=0x58; TR0=1; while (TF0 == 0); TR0=0; } } delay_us(unsigned char val){ if (val == 40){ TMOD=0x01; TH0=0xFF; TL0=0xD8; TR0=1; while (TF0 == 0); TR0=0; } else if (val == 35){ TMOD=0x01; TH0=0xFF; TL0=0xDD; TR0=1; while (TF0 == 0); TR0=0; } } void set(){ DTH=0; delay_ms(18); DTH=1; delay_us(40); } void response(){ while (DTH==1); while (DTH==0); while (DTH==1); } unsigned char data_transmit(){ unsigned char datas=0; for (i=0;i<8;i++){ while (DTH==0); delay_us(40); if (DTH==1){ datas = (1 << (7-i))|datas; } while (DTH == 1); } return datas; } void main(){ lcd_init(); while (1){ set(); response(); humidity = data_transmit(); humidity_point=data_transmit(); temperature=data_transmit(); temp_point=data_transmit(); check=data_transmit(); cmd(0x80); if (check == (humidity+humidity_point+temperature+temp_point)){ show("humidity:"); h[0]=(humidity/10)+48; h[1]=(humidity%10)+48; show(h); } else { cmd(0x80); show("Checksum Error!"); } lcd_delay(); cmd(0x01); } }
