Hydraulic wood splitter
The device can split wood of 0,33m, 0,5m and 1,0m length. It can work vertically and horizontally.
It was made in garage. Useful tools were: welder, drill, power tools and hand tools.
  • electric motor 5,1KW, three-phase, 2850rpm
  • maximum pressure: 7,5t (150bar set on overflow valve)
  • speed: working stroke of 6cm/s, the return of 12cm/s)
  • maximum stroke of the piston: 25cm
  • the diameter of the piston: 8cm
  • pump: 6,3cm3/rotation, 250bar
Also needed: steel materials, motor, hydraulics: pump, divider, overflow valve, manifold block, pressure gauge, wires.
Link to original thread – Hydrauliczna łuparka do drewna
