Hybrid library vs normal one
testhp
Newbie level 3
Newbie level 3
Hello,
We use Orcad and we want to update our libraries. When we place a part and want to rotate it,we don't like the layout of the names and values and thus have to manually reposition them. It's not a big deal but it gets annoying after a while.
To solve this issue, we came with two solutions:
-Create for one component two parts(an horizontal and a vertical one)
-Create a symbol with the convert option which allows us to choose in a click
Does anyone here have any suggestion on what would be best ? I'm leaning towards the convert option because it seems faster and we have less components, but my supervisor would like to know what people in the industry do. I've linked some images to clarify what I mean. Thank you very much, and even if you don't use Orcad,if you have an informed opinion, I would still like to hear it
https://imgur.com/a/iVTt5eW
this has been a question (problem?) since the first schematic capture package.
i move the attributes.
Yes, it's very annoying but between the two solutions, which one would you recommend ? Thank you
i choose to move the attributes rather than producing two symbols for the same thing
as it is, i have two symbols for some things because one refers to a through hole form factor and the other to a surface mount form factor
if i had two symbols for vertical and horizontal, it means i need 4 symbols for the same thing.
I see thank you, more symbols can be bothersome sometime
