davoud
Full Member level 2
Hello guys
I want to make a H.V.H.F Transformer (25Kv – 10ma).
So I want to turn a transformer.
Last time I made a Trans with fly-back circuit and I reached to this voltage but coils burned because of corona inside wire winds.
Next I wound coils and coated them with a type of high voltage strength Resin.
In this part I did wonder when I connect it to circuit board and turn it on.
1-Resonance frequency was changed and was very low (before curing we had 11.KHz and after curing with epoxy I had about 1 KHz).
2-When I connect it to rectifier and regulated it with capacitance there is not enough current for staying to this voltage and the Voltage dropped to 300v.
I don’t know where is the problem?!
I thought there wasn’t enough Flux, So I turned a greater primary coil but I hadn’t any Promising result.
I would be thankful for any suggestions.
