HV9821 LED driver current sense resistor conenction is wrong?
T
treez
Newbie level 1
On page 3 of the HV9821 LED driver datasheet, howcome on page 3, the high side current sense resistor is connected to ground?
HV9821
So there could be 700V one side of this resistor, and then ground on the other side of this resistor?
I don't see a ground connection of Rs.
Reactions: treez
    T
on the "functional block diagram...inside the controller there is a ground symbol.
But the IC hasn't a ground pin. The block diagram clarifies that the ground symbol refers to the OUT pin.
Reactions: treez
    T
I agree, but why is the Rs connected to it?
Output current is sensed at the OUT pin, I think. So what's strange about it?
Reactions: treez
    T
The buck freewheel diode cathode is grounded in their diagram
May be I didn't yet get your point, but the diode connection is also typical for a buck converter.
Reactions: treez
    T
I really don't get your point. :?:
Very regularly, the cathode is grounded. The anode is not grounded.
Reactions: treez
    T
but your picture shows the anode of D1 directly connected to ground , as it should be.
If you open out that picture above, you would see the cathode of D1 has got a ground connection , which it shouldnt have.
You are confusing the substrate connection inside the chip with a ground connection. See my post #4.
Reactions: treez
    T
